  #41
Old 03-26-2013, 11:56 AM
Very much agreed
Old 03-26-2013, 10:23 PM
martin martin is offline
Default transom
ground off the excess. And cleaning up the skin I should have done this when the skin was just pulled off and the wood was wet.. Would have been easier.. Boy I wish I had a belt sander..
Old 03-27-2013, 12:31 AM
scowman scowman is offline
Default Outer Skin
That outer skin looks beefy. How thick is it?
Old 03-27-2013, 05:31 AM
hermco hermco is offline
Do you mean an air chisel with a wide blade?
Old 03-27-2013, 06:54 AM
I saw something new at lowes that would work well for this. It was a wide scraper blade on a chisel that would fit a standard sawzall. They were only like $10 and it looked like it would work well for something similar to what you had to do.
Old 03-27-2013, 07:35 AM
I use my dewault 7 inch buffer/grinder with a 16 grit pad on it with the variable speed all the way up. Actually works better when the wood has dried.
Old 03-27-2013, 10:58 AM
Yea 10/4... I will be getting a larger grit disc...using 36 right now... I ager workable better when wood us dry... When wet though the wire cup brush just ate awayat the wet wood....hope to have it done this weekend. Weather permitting...
Old 03-28-2013, 11:33 PM
about a 1/4 inch
Old 03-28-2013, 11:41 PM
Has anyone installed a reverse chin. so that to knock the spray down.. I like the look of spary rails. but dont want to install them.. I was thinking of putting a1/4 reverse chine on the chine startin at the bow and flaring it down about3/4 of the leghth of the hull. I know what you guys are probably thinking. But I heard these are wet boats... I have never ridden in a 23 But my buddies 24century has a reverse chine and it does not matter what angle or how hard it blows you don't get wet... So what is your thoughts and how does yours ride .in rough weather..
Old 03-30-2013, 11:02 PM
Well I decided to scrap the skin idea. Reason being is that I did not realize that the outer two skins i put on the boat were already at the stern. Meaning flush with stern. So I decided to just start wrapping the glass around the stern quarters.. I did a 1808 o-90 came out just under the hull gellcoat.i wrapped up about3 -4 inches... I finished this one Thurs day night. just to find Friday that my heat lamp got a little to close.. So now I had to repair the core cell. Friday night. I just ground down the corcell until i got to clean material. then i added 4 pieces of glass or until it was just over .. I wrapped up it with a piece of visquen to keep the material in place. My epoxy as it gets hot it gets more liquid or viscus.. O i had to place a piece of visquene on it to keep the glue and glass in place. Sat i ground the glass flat and this time ground the stern quarters farther down the hull side about10 inches and tapering up at a 45 degree angle. so that there is more there to keep the transom from ripping off.. I glued a 17-08 0-45 piece of glass to the transom ... once that started to get really tacky. I wet out a piece of 2oz mat. i mean really wet out...WHAT a PAIN IN the ARSE ..after the mat I mixed up some cabosil and resin and smeared on to my backer board and onto the mat...I had the bright idea to build a flat very flat panel so that i can mash it up against the wet glass and get a smooth and flat surface to fare to... I will let you know what it looks like... I may have just created a really big Mess..
