  #41
Old 04-14-2017, 08:15 AM
sisu22 sisu22 is offline
They work great , color is growing on me
Old 04-14-2017, 03:21 PM
How did you install them - did you have to take the glass out of the frame as Gilly said?
Old 04-14-2017, 04:32 PM
jonbrush jonbrush is offline
The ladder clips Mitch (flexpat) and his son made for me were a vibrant purple. I painted them white which looks a bit better to my eye.
Wonder if there is a reason that the 3D printing process involves these amazing colors.
PS Any way to get a few of those clips?
Jon Brush
Old 04-21-2017, 08:16 AM
no sailor ,i just pulled down under pressure ,and the nut came off same going back on
Old 04-21-2017, 02:12 PM
FLexpat FLexpat is offline
Originally Posted by Eric B View Post
need some help on this topic. I attempted to remove one of my 4 broken latches yesterday with a socket on the nut holding what was left of a latch. The entire bolt was freely spinning and therefore could not get the nut off. What is the trick here? I attempted to use a flat head screw driver to put some pressure on the bolt at a angle but was hesitant about pressure so as not to break the glass.....can I get a little help????
Sounds like the threads in the aluminum frame have turned into aluminum oxide powder. A few options:
1- Cut the old latch off. Grip the threads with needlenose visegrips and remove the nut. Epoxy the bolt in and use a die to recut the threads.
2- Cut the old latch off. Grip the threads with needlenose visegrips and remove the nut. Using the visegrips to hold it recut the threads with a die and then run a nut down to lock the bolt into place. The replacement latches would need to be shortened by the thickness of the new nut.
3 - combine both of the above.
4 - Pull the windshield glass and replace bolts with slightly larger ones.
Old 04-23-2017, 08:36 AM
classictwenty classictwenty is offline
Albemarle used these on their 24' . Contact them.
Old 01-31-2018, 11:49 PM
dginge dginge is offline
I’d love to replace one or all of mine. Any advancements? I could not get mine off either
Old 02-01-2018, 12:10 AM
If the nuts are seized onto the threads, try getting some Kroil (Amazon has it) and soaking for a couple of days to see if you can get the nuts to loosen up. My earlier post on this thread had my best guesses for the mechanics of getting them off after some chemicals get used.
If/when you get the nuts off PM me and I can send you a .stp file that you can upload on Shapeways.com (or most 3D print services) to 3D print the latches. Let me know if you use a SS nut to hold the bolt so I can adjust the latch shape to match. Use either HP Nylon (Nylon 12) or 'Strong and Flexible' which is a cheaper nylon.
I would just upload the file but this website says it is an invalid filetype.
Old 02-01-2018, 12:55 AM
Damn you make me think. Whatchadoin for Mother’s Day?
Michael.
Old 02-01-2018, 08:17 AM
Thanks so much for the info. My nut and fixture show no signs of corrosion but since it’s a lock nut it simply will no come off. It’s killing me. The bolt just turns freely. So when I get them off, your saying, that I can send that file off and the company will make me 4 of them?! That’s awesome. Thanks
QUOTE=FLexpat;255963]If the nuts are seized onto the threads, try getting some Kroil (Amazon has it) and soaking for a couple of days to see if you can get the nuts to loosen up. My earlier post on this thread had my best guesses for the mechanics of getting them off after some chemicals get used.
I would just upload the file but this website says it is an invalid filetype.[/QUOTE]
