#41
Hi Oldboat,
Great boat. We had a 71 IO. Did you buy or build the hatch receivers? I am debating the make or buy decision because I have not found any that match the dimensions I need. Best regards, Ed |
#42
I bought both hatchs complete from gulf stream and I am very happy with them. They feel very solid in my 1 inch coosa decks. well worth the cost if u calculate time and materiel to build and another thing done on the forever list.
#43
Got the coosa decks glass down finishing tabbing to start glassing deck surface
#44
Looking good! I'm sure that deck is solid as hell.
#45
Real happy with it.its like a brick even with no glass either side yet. What I found is that the coosa without glass stay really flat and strait so I put a lot of work into getting every thing level so when I glassed in the boards they would align perfectly without putting weight or shims anywhere ,just put my epoxy (mix butter) thick so no gaps and a really nice level deck and just lay them in there. I saw a guy put battery’s and thing on his and it was very wavy uneven. I think I just got lucky for I never did this before.
#46
Cracked open another roll of 1708 (115 pounds) . Starting to cut first layer of 1708. The second layer will go up the side to were grinding stops. Hot out the s morning .
#47
I've never used the coosa without both sides glassed with 1708, however I can't see why it would not be very strong glassed on just the top like you are doing! Since there is less than 1% water absorbstion with the coosa, waht's the difference if the bottom is not glassed?? When you get it tabbed to the sides it will be very strong!!! Good luck!!
#48
I didn't put any glass on the underside of mine either. Solid as a rock! I kept reminding myself of the 2 layers of continuous strand made into the board.
1975 SF18/ 2002 DF140 1972 15' MonArk/ 1972 Merc 50 http://i833.photobucket.com/albums/z...photos/SC3.jpg |
#49
I’m not to worried about it .
#50
Yeah I wouldn't be either. Here is a guy who submerged a scrap piece of Coosa for 5 years. Not a very scientific test, just soaking a scrap piece in tap water, but still has some merit for absorption rates. To quote someone from that thread:
