  #51
Old 09-21-2011, 07:41 PM
george90 george90 is offline
Default Re: 23 CC rebuild - shine
with out the liner would this make the boat easyer to crack and wouldnt that take off alot a weight
My goal in life is to restore as many classic seacrafts as i can.
Old 09-22-2011, 10:29 AM
shine shine is offline
Moderator
I replaced the stiffness by adding all those frames and stiffeners you see. Yes, it should be lighter than the liner, but not at the expense of stiffness.
Old 09-24-2011, 07:33 AM
with that big of a weight change how much would that effict the ride of the boat. i know a heavery boat handles waves better.
Old 12-07-2011, 05:33 PM
Moderator
Wink
Its not so much of a difference to throw off the ride of the boat. Besides, it not useful weight that I removed - If my SC hull is 300 lb lighter, then I can just carry more ice/beer/people/fish at the same weight/fuel burn.
[img][/img]
Will be painting soon
holes for bracket, drilled out to 1 1/2", then filled with milld fibers, chopped glass and epoxy, then 1/2" holes for bracket bolts re-drilled. Did this for all the hardware as well
Taking the old paint off. Then high build primer on the hull and insides.
Goal is to have her ready for rigging by Christmas
Old 12-07-2011, 08:17 PM
everybody everybody is offline
uhhh thats a bad ass build. How many years of experience go into a project such as this?
www.lionheartlandscapes.com Design, install, and concrete pavers. Will travel
Old 12-20-2011, 04:10 PM
Moderator
Smile
----- How many years of experience go into a project such as this?
Thank you. I have rebuilt one other boat from the hull up, made numerous repair, and built a few boats from scratch (one off designs). Im not a professional boat builder, but I do sell materials to them so I have to know what I'm doing Rebuilding a boat is well within the grasp of anyone with a little bit of handiness and a lot of willingness to learn. With the internet, everything you need to know is right there, just takes wanting to learn it.
Primer is all sanded to 320, boat will get its first taste of sterling topcoat next week. plan is to paint the bracket and hull outside first (Ice Blue), then paint the inside (Matterhorn White), then light gray Kiwigrip non-skid. I may spray the inside sides, just because of all the inside radii. Hull will definately be rolled and tipped though.
next pictures I post should be good
Old 12-20-2011, 05:08 PM
Shine, this restoration is coming along nicely. A lot of thought and hard work. Good luck getting her painted and rigged!
Will
Old 12-20-2011, 08:15 PM
Joel,
Looking good, man. That structural grid you added to the sides looks strong and light. But I don't envy you the fairing and sanding it took to make it look so pretty. Can't wait to see it with the top coat on.
Dave
Blue Heron Boat Works
Old 12-21-2011, 09:10 AM
gw204 gw204 is offline
Why the decision to roll and tip the hull when you have the capabilty of spraying?
Brian
1981 Mako 17
Old 12-21-2011, 04:03 PM
csurf csurf is offline
What did the console come off of? Kinda looks like a something from a Contender.
1980 23' SeaCraft
1992 16' Steiger Craft - Custom Flats Boat
The sea finds out everything you did wrong.
