  #51
Old 01-27-2011, 09:43 AM
Default Re: 1977 20ft Master Angler Restoration
Thats a good idea. I will do that first thing this evening. Hopefully nothing is off to bad and I can get it corrected now.
Thanks again.
Old 01-28-2011, 01:34 AM
Well everything seems to be good to go. Pulled some strings and they layed on one another just right with either one on top. Also rough cut a bulkhead for the front, where the anchors will be stored. Maybe Saturday I can get the floor screwed down.
Old 01-31-2011, 12:48 AM
Got the floor screwed down and the anchor locker cabosiled in. I will sand it down tomorrow and lay the glass this week. The top cap is still loose, thats why it looks uneven.
Old 02-01-2011, 03:32 AM
Sanded it down tonight and filled the last couple of low spots.
Old 02-03-2011, 03:50 AM
Dry fitted the glass tonight. I will get it glassed in tomorrow night. Also made some molds for the rigging and gas lines.
Old 02-03-2011, 02:25 PM
Wildman Wildman is offline
What size PVC did you use? Did you have to trim the slots in the stringers a little to get it to fit?
Old 02-03-2011, 03:57 PM
It is 3". I sanded all the high pieces of glass that were in the way. It was a tight fit and you had to push it down in there. But I do not think with it being in there tight would cause any trouble. I put some cabosil on top of it, mainly because I had some extra. I also drilled about 6-7 holes in the bottom of it on each end in the event water got down inside it because it is not going to be sealed up at either end.
Old 02-05-2011, 02:09 AM
Old 02-06-2011, 02:44 AM
Sanded down the transom and fitted the molds.
Old 02-06-2011, 09:22 PM
basswacker basswacker is offline
What is the purple puddy type stuff that you used?
Basswacker
Mmfishinglures.com
1976 23' Scepter
Lift weights get dates
