  #51
Old 03-30-2013, 11:14 PM
martin martin is offline
Default transom pics
here it is .. I also had time to clean the bracket up I used a soda wash mixed with some sand to blast the noocks and crannies .. then I pressure washed for ever.. then let it air dry for a bout an hour, then I used a ppg Alum cleaner and shot with 545 Algrip primer
Old 03-31-2013, 12:18 PM
What did you coat that bracket with?
Old 03-31-2013, 01:59 PM
Default Bracket
I was told that the 545 algrip primer good on all substrates above and below water line...
Old 03-31-2013, 09:33 PM
Forgot to show the part before the burn out oven.. my friend owns a motor rewind shop in town. he let me use his oven to vaporized the rest of the powderecoat.. after it was pulled I blasted with baking soda and sand ...
Old 03-31-2013, 09:43 PM
Default bracket
here it is with a 250 hp motor stator.. the oven is 6' x 6' x h7 '
Old 03-31-2013, 10:46 PM
How hot is the oven? There is a sort of upper limit you want to respect with aluminum in terms of time at temperature. You are probably ok, but it is worth thinking about, as it can reduce the strength of the aluminum.
Old 04-01-2013, 03:57 PM
Yea 10/4... Well we hqve burned out many slum stators ..iron core.. and had good luck... These are pumps qnd motors with flow tollerancea for bearings and shaft alignments... I know that there are set points as to what materials are being burnt... I think he had it set at 800. For 3 hours.... Then u slowly bting temp down... I did not see any warping or cracks... I did spray some crack dye just to check the welds
Old 04-01-2013, 04:01 PM
Default bracket
We will see wen I put her through the paces 4-6 foot chopout saint Andrews passq
Old 04-01-2013, 05:32 PM
Yea i looked at that boat.. How does it run? Theres aguy in santa rosa that fly fishes off his. He runs charters in the summer.. I pass him every afternoon on the road.. And wish when i retire i can do what he does... Fish everyday
it runs suprisingly well... the old 115 pushs it fine for now... scrubbing and replacing the wood leaning post .. trim tabs... may look at transom replacement over the winter before trying to repower.. going to run it for a while and check the burn numbers .. if the old tower of power isnt to bad i may try to stay with it for the classic look.. the original plan was to close the transom... but im not so shure yet..
RUSTY PARKER
Old 04-01-2013, 08:21 PM
It's not a stress/warp thing, it's a strength thing. Some aluminum alloys lose a significant portion of their strength when heated near their melting point. You might want to look at the alloy the bracket is made from and find out if annealing it causes it to lose strength. On the other hand, if your friend routinely cooks aluminum in his oven, he may already know the tolerances.
Dave
Blue Heron Boat Works
