  #61
Old 02-05-2015, 10:23 AM
martin martin is offline
Originally Posted by slowJEEP View Post
Started grinding the old wood and blistered glass off the transom today. New grinder and flap disk made quick work for a little while. Half done and the flap disk is slower. Anyone have a better glass grinder than a flap disk?
Twisted Wire cup wheels.worked great for me. They chewed the wood up pretty good with out loading up
Old 02-05-2015, 12:20 PM
slowJEEP slowJEEP is offline
I presume that removes the wood and leaves the glass behind?
Old 02-05-2015, 12:51 PM
Yes and a thing that is not adheared well to the glass. Works great for wet wood as well
Old 02-05-2015, 01:01 PM
I've noticed the stringers are cut away from transom. Make sure to have the trailer bunks run all the way past the transom to help support it. You don't want a hook created in the bottom of hull. Just a thought.
Old 02-05-2015, 02:07 PM
Good point. I have some boat stands coming. I wonder if they'll make any droop better or worse. Either way, I'll give it a check b/f I glass the stringers back in.
Old 02-05-2015, 04:59 PM
Default transom
Your outer skin is definitely thicker at about a1/4" boats stand on the stern chines should be okay.. Just check with a straight edge of on time to time... Hopefully you won't be 4 years into your projects like me .lol
Old 02-05-2015, 07:18 PM
foolharty foolharty is offline
The coremat equivalent was in my 86 as well. I use the 24 or 36 discs on a grinder together with one of the thicker metal cutoff wheels. Its a little ghetto rigged but works (4 1/2" grinder)
50 Ton, '72 SC 20
Old 02-05-2015, 09:19 PM
Have a picture of the grinder disk arrangement? I ordered some aggressive looking disks off of Amazon today. Hopefully they are the hot ticket.
Old 02-05-2015, 09:45 PM
Default wire cup
Make sure you use your handle grip on your grinder and gloves.be careful cause when it hooks up..
Old 02-06-2015, 05:50 PM
I'm in the planning stage. Been using the computer to help guide my thoughts. Whatcha think?
lifejacket Storage/step in the bow (reuse some of the casting platform)
Fix box in the floor
50gal livewell in front of the console
Console narrowed to 30ish inches w/integrated T-top supports.
Bilge access behind the rocket launcher
Debating putting storage boxes across the transom. Could be dry storage or little livewells.
Tags
175, 20sf, optimax
