  #71
Old 05-01-2017, 07:35 PM
It's grinding and sanding time
Old 05-01-2017, 08:09 PM
Ah, the fun part.
Old 05-01-2017, 08:54 PM
lelandtampa lelandtampa is offline
jorge how heavy was the cap when you took it off?
Old 05-01-2017, 09:00 PM
Not heavy at all. 3 guys. Make sure to use some cross braces
Old 05-01-2017, 09:23 PM
Not really took 3 guys. More was not letting it flex and crack it. I user some 2x4s as cross members to not only help in picking up and flipping it but also not let it flex
Had a look of rotten wood in the areas such as rod holders and lights.
Replaced wood with nida core and and new foam which most was missing.
If you have it off for an extended time cross brace the hull so it won't flair on you.
Ask me how I know....
Old 05-04-2017, 07:56 PM
Almost done with the transom. Getting it nice and smooth
Old 05-05-2017, 07:09 PM
Jorge how did you fill the gap between the liner/ edge of floor and the hull? mine is cracked all along. i am probably going to lay some foam strip in then some arjay then tabb it into the hullside with resin and tape.
Old 05-05-2017, 07:17 PM
well I finished the sanding on the transom and splash well. It came out pretty good although the pictures don't show it.
Question should I lay a coat of primer over that area since I will be tackling the floor and rest of the hull and I'm worried about the rain and sun ?
Old 05-05-2017, 07:23 PM
Now to the floor.
I did the floor with Nida Core and layed several layers of mat on top.
I feel like I need an additional layer and was thinking of a layer of 1704.
Me and my 2 sons all weigh over 225 and I don't want any issues down the road.
Also there are some low spots that when I hose it with water I can see.
Was thinking of 1st hitting it with a layer of mat to bring it up prior to the 1704 mat.
Then fair and back to sanding it.
I don't think it needs to be perfect since it will be covered with non skid but I would like it to be as level as possible.
Looking for what some of the others here have done??????
Old 05-06-2017, 08:03 PM
Took a break from sanding the boat and gave some attention to the 2 deck hatches that covers the gas tank. Took the old non skid off both. And I took out the square inspection cover that was over the tank. It was ugly and in my mind just let water drip onto the gas tank.
Then I got out the original splashwell and noticed some staining on it from wood rot. Sure enough the thin layer of wood on the curved part was toast. Was able to use a blade to take the skin off the inside uglier side and took out the rotten wood. I guess it's an easy fix.
Update on the splashwell. Ground down the old wood and took out some left over nida core scored it to accommodate the curve and will glass that in.
Tomorrow is another day
