Old 04-28-2003, 07:25 PM
CMBarnes CMBarnes is offline
Default Replacement Vents
I am in the process of restoring a '75 CC and the vents on the boat now are stainless and all bent up. Does anyone know where I can find replacemtns? I would like to get the stainless again as they would match the aluminum T-top that is about to be installed. I tried a search through old threads but couldn't find the answer. I believe someone has written on this subject in the past. Thanks for your help!!
CMB
If I can only find plastic I might fill them in. Is this a bad idea?
Old 04-28-2003, 09:14 PM
Default Re: Replacement Vents
Probably won't help but mine are plastic on my 78. I took the ones off the sides of my console and put them on the bow. Not certain if all are the same but the hole that the cover inserts into is smaller than the vent. Since I have plastic I just put the inside part on the bandsaw and removed about 3" on each end for them to work. They are well worn also but at least they were not broke allup like the oter ones. I had some black ones off a 78 formula that are going in the sides of the console. good luck-craig
Old 04-28-2003, 11:22 PM
Finster Finster is offline
Mines a '72 and in the same condition. I notice the other day in one of my locals the exact same ones in stainless and plastic. I am sure if you go to any reputible boat supply you can find them or order them.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 04-29-2003, 04:08 PM
Brian Rice Brian Rice is offline
West Marine carries the vents in either plastic or stainless.
Old 04-30-2003, 11:17 AM
Thanks for the help!
CMB
Old 04-30-2003, 11:20 AM
Eric McNiff Eric McNiff is offline
http://www.westmarine.com/webapp/wcs...roductId=52947
Eric
My wife does not care for the 2 boat theory
