Old 03-31-2004, 08:44 PM
Default Transom Angle
I measure about 13 degrees on my mine......does anyone know what the specs are as to the transom angle on a 1970's 23cc. Thanks
Strick
Old 03-31-2004, 11:19 PM
lost2a6 lost2a6 is offline
Default Re: Transom Angle
I came up with about 12 degrees on my 23 Sceptre.
Steve B
Old 03-31-2004, 11:41 PM
Thanks Steve
Anyone else have anything different?
Strick
Old 04-01-2004, 12:38 AM
Scott Scott is offline
12 degrees here also
Old 04-01-2004, 08:35 AM
OK thanks guys... I've re-measured and re-measured and still get 13 degrees. I'm using a protractor and table saw mitor for my measuring devices. Maybe my boat is different.
Strick
Old 04-01-2004, 11:27 AM
gw204 gw204 is offline
Here's how I'd measure it:
1. Hold your framing square so the short leg points up and the long leg points toward the bow of the boat.
2. Place the square so the tip of the short leg contacts the transom and the long legs sits flush against the bottom of the keel.
3. Divide the measurement from the inside corner of the square to the transom on the short leg by the measurement from the inside corner of the square to the transom on the long leg.
4. Take the inverse tangent of that number (calc.exe in scientific mode) can do this and you have your transom angle.
Does that make sense? If not, just send me the measurements. [img]/images/graemlins/smile.gif[/img]
Brian
1981 Mako 17
Old 04-01-2004, 01:50 PM
I knew I should never have thrown away my old Trig book.
A squared + B squared = C Squared.... Got it! thanks Brian [img]/images/graemlins/grin.gif[/img]
Strick
Old 04-01-2004, 05:11 PM
afernand afernand is offline
I am new to boat re-building: why is important to know the angle of the transom? Thanks for your answer, aaf
Old 04-01-2004, 07:20 PM
I am making a fiberglass motor bracket for my boat and I was just making sure I had the right transom angle for the mold. I still get 13 degrees so that is what I used.
Strick
Old 04-01-2004, 09:11 PM
Thanks for info. --aaf
