Old 02-18-2007, 08:47 PM
Tensho Tensho is offline
Default OH NO!!! BLISTERS
Need some help. Well as I had stated I just bought a nice 1984 23 foot sceptre. In the process of peeling away the 6 coates of bottom paint we just discovered blitering on the waterlines on the port side. We are still peeling away the the bottom paint on the hull but thus far I have been able to feel some blistering down there too! I was just going to stip the layers of bottom paint down and give it a nice new fresh thick layer but what do I do now? Any help is great help....
Thanks everyone.
Old 02-18-2007, 11:18 PM
thedink9 thedink9 is offline
Default Re: OH NO!!! BLISTERS
Some pictures showing the severity of the blistering may help in making recommendations. Dink
Old 02-18-2007, 11:42 PM
I will definately get some online tomorrow. The blisters aren't that large, about 1/4 inch to 1/2 an inch in diameter, but there are a lot. Looks like a teenager during puberty. They don't pertrude that much but are obvious in sight and touch. They are hard too, not watery as I expected.
Old 02-19-2007, 10:24 AM
Bryan A. Bryan A. is offline
If they are not to deep you could probably sand them out then epoxy barrier coat over them.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 02-19-2007, 10:38 AM
Thanks Bryan,
My father in law said the same thing after he saw it. I think I am going to hit it with some Interlux Epoxy, then some Interlux Micron bottom paint. The guy who had the boat had it constantly sitting in the water for 2 years.
Thanks,
Tommy
Old 02-19-2007, 12:08 PM
Tommy
The epoxy will run unless you thicken it with something. West System makes a collidial silica in a 1 quart can that will do the trick. Mix it with the epoxy until it has a peanut better consistency then trowel in on. you'll need to clean up the holes a bit first with something to remove any loose getcoat and then wipe with acetone before applying.
Good luck. Dink
Old 02-19-2007, 01:02 PM
When I said barier coat, I meant applying to the whole bottom after stripping, then you can apply your CSC or Micron. I have done that on more than a few older boats and the system works out great. If you are stripping the entire bottom it just makes sense to coat the whole thing. This is the product I used. If you have any more questions, feel free to ask.
Parker 2530 DVEC
Old 02-19-2007, 07:35 PM
nestorpr nestorpr is offline
Don't you have to let them dry (after you open them up with a grinder) before you apply anything?
Boatless again!
Old 02-19-2007, 10:32 PM
paulfurnari paulfurnari is offline
I would be careful using paint strippers not spec made for the marine industry. I used a so-called fiberglass safe stripper on bottom paint and noticed small pox mark like blisters and think they were caused by the stripper-PF
Old 02-19-2007, 10:44 PM
Solafide Solafide is offline
You should open each of these with a grinder and let them dry out completely,heatlamps will help with this,otherwise the epoxy will be a short term bandaid.best of luck
Alan
