Old 03-11-2007, 12:38 AM
hvaldezz hvaldezz is offline
Default rub rail question
Has anyone replaced their aluminum rubrail with a rubber one lately? Can this be done easily? Any tips on doing the work?
Thanks for any input.
Hank
Old 03-11-2007, 09:04 AM
Default Re: rub rail question
Taco sells some nice ones, lots of choices. You will probably need heat and help for the corners
Old 03-11-2007, 11:14 PM
joseeli8797 joseeli8797 is offline
I recomend you go with a rubber rub rail instead of rigid vinel rubber you wont need a heat gun and second they hold up better when bumping the dock, and as far as installing ,you get a 50' section of rub rail find the middle and screw two screws through rub rail onto the bow of the boat, then take the two ends one on each side and pull them straight back over the corners of the transome nice and tight now put 2 screws on the port and starboard back corners through the rub rail , now you can walk on the side of the boat and pull the rub rail like a big rubber band over the flair or curve of the gunwall and it should be tight enough where it does not sag down , line it up with the cap and screw it in , this job usually takes me and my helper every bit of two to three hours sorry I dont have pictures of the process good luck.
www.fiberglassman.com
Old 03-17-2007, 11:28 PM
They even got White rubber rubrails for the Good old boy's
Old 03-18-2007, 02:39 PM
Fiberglassman, thanks for the solution you offered. Can I order one of the rubber ones from West Marine or do I have to find a different source? I like your idea, it seems like it's lots simpler. I hope to do this within the next month or so.
Look forward to your answer.
HankV
Old 03-18-2007, 09:17 PM
Thats fine, or almost any marine supply should carry Taco metal rubrail assortments.
Old 03-31-2007, 08:54 AM
There is also a distributer called railings unlimited in FT lauderdale Fl.
Old 03-31-2007, 09:47 AM
hermco hermco is offline
Give Alan a call at rubrails.com he is a great guy.
web page
