Old 03-21-2011, 08:05 PM
fishbuster fishbuster is offline
Default Hull side coring?
Going to replace the coring on the Dusky that was originally 1/4" fiberglass liner with something either like 3/8" balsa or foam core. Was wondering what you input is on the coring and what type you would choose.
Going to be using 2 layers of 1708 with vinylester resin. The only things that would be going thru-hull would be the bilge and fuel vent well above the water line.
Here is two options for foam core Armacell http://www.armacell.com/www/armacell...7?OpenDocument
And the other is Airlit by Baltek http://www.mertons.com/Floatation/scored_foam.html
What would you choose if it were your boat and why
Randy
