Old 07-07-2011, 07:08 PM
abl1111 abl1111 is offline
Default Awlgrip - where is it safe to spray ?
I need to spray a boat with Awlgrip, and lost my buddies factory to do it in. Is it safe to spray outside in a neighborhood - I'm worried about overspray; cars neighbors houses, etc.
Old 07-07-2011, 08:11 PM
Default Re: Awlgrip - where is it safe to spray ?
The 454 primer won't be a problem. It dries so fast, the overspray is a powder you can sweep up. The top coat is another matter. I sprayed mine inside, so I can't say with certainty what distance is safe for the top coat. I would think at least 25', but some of the other guys with more experience may have a more accurate idea.
Dave
Blue Heron Boat Works
Old 07-08-2011, 12:59 AM
Your gonna want to spray it inside or under a covered carport of sorts because bugs and debris will get on the wet paint and then your not going to be happy.
Old 07-08-2011, 08:21 AM
Dave
I think you meant 545..
See ya, Ken
Old 07-08-2011, 10:01 AM
Thx guys - Strick, I knew that was the right answer - just didn't want to face it ! The search is on !
Old 07-08-2011, 04:12 PM
See ya, Ken
Yeah, I did. I'm the victim of age induced dyslexia. Wish that was the firs time it had happened.
Dave
Old 07-09-2011, 10:15 AM
I'm not sure if anyone mentioned it, but here on LI with the way the humidity settles out of the air every night, you will definitely want it covered. I basically built a tent over mine, but I was only doing the deck.
Old 07-10-2011, 09:03 AM
I hear'ya. Last time I sprayed I waited for the weather report to be perfect. Then I sprayed the 545 outside and then built a large oxygen tent out of huge sheets of plastic within an industrial building and sprayed away. Came out great.
I asked an auto-body guy I know if I could use his room fopr a few bucks on a Sunday, but he said that his room is not set-up for something like Awlgrip...
Old 07-11-2011, 07:21 AM
They also make an accelerator for 545.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
