Old 08-31-2011, 03:13 PM
CBradC CBradC is offline
Default Project questions
I will try no to ramble but I am slightly overwhelmed by this potential project and am seeking advice. I have a chance to pick up a mid 70's Seacraft 23 cc with a straight inboard. The boat is rough but seems solid. The engine , transmission and all associated components are in place but have been submerged in freshwater for along time and I believe are beyond use. Is it possible / practical to add a bracket and an outboatd to this hull or would it be better to restore it as an inboard. It has a tunnel in the hulls bottom to accomodate the shaft and prop so I have no idea if a bracket could work or not. Any ideas on the costs to replace everything from the engine to the prop? Thanks for your opinions , standing by!
Old 08-31-2011, 07:59 PM
Default Re: Project questions
I'd repower with the inboard. They're great fishing platforms, and it will cost much less than bracket and outboard(s).
Old 08-31-2011, 10:56 PM
If the boat was sunk you are going to have wet stringers and deck I'm just guessing the boat sunk or flooded with rain water ! You might be in for the same situation I was or still in
1979 Septer I/O no power Sold
Old 09-01-2011, 12:47 AM
BigLew BigLew is offline
Before I put any money down, I'd have it surveyed! Then you will have a better idea of what you are buying. At this point all you know for sure is that it is the right brand and you've got a dream with some money and sweat to back it up. If the item is not up to a basic standard you are willing/able/can afford you are in a heap of disappointment and cost.
The cost of a quality survey will be money well invested vs. the expensive wild goose chase you are possibly looking at without the survey.
Just my two cents! Good luck!
Plan accordingly!
