Old 05-28-2012, 07:52 AM
Default Trim & Tilt question
I have a Merc Black Max connected to a Merc Binnicule.
The harness starts the engine fine
Coming out of my binnicule the is a 3 wire set the finishes with a plug that goes to something.
I imagine that this is for the trim to work from the binnicle.
I imagine that I need what ever plugs into the 3 wire set/plug and that that goes somehow to the engine. Selenoid / relays??????
So what do I need to get it to work?
Please enlighten me
Old 05-28-2012, 08:44 AM
check and see if it may be your tach lead
Old 05-28-2012, 06:43 PM
whenever your ready ill bring mine over for ya
Old 05-28-2012, 08:05 PM
Did some digging under the console and got the wiring done for the trim
I have a bad selenoid and I know that I need some trim fluid.
Now I need to figure out the way to add the fluid and get it working right.
Thanks for the advise given
Evan I will call you this weeek
Old 05-28-2012, 09:57 PM
if i remember for fluid you use regular atf. i have it in mine for years now with not issues. if you want to drain it i think you can remove the white manual release valve and the fluid should come out. i will look into the filler procedure for you.
Old 05-29-2012, 05:33 PM
On the solinoid - the outboards have little rubber grommets and the mercruisers don't - same one - those are some damn expensive grommets LOL - save the old ones and use them. I tried a NAPA one which is Sierra, only lasted a year so went back to Merc but the dealer found that little trick with the grommets
