Old 02-24-2003, 08:46 PM
Default Re: Water pickups and Seacocks
Billybob. use 4200 in case you want to take it back out later. I am trying to remove one now that I put up in the forward hatch that I intended to use as a live well. I used a scoop with a ball valve on the inside the boat and 5200'd in place- believe me you dont need the little screws to keep it from turning. [img]images/icons/rolleyes.gif[/img] . The hold constantly fills up with water with no good way to remove it other than a 5 gallon bucket, but thats my problem. The higher dollar seacocks dont have the strainer built in, it is added on seperately.They ambettr quality than the ball valves though.I lvat thells thck eng at you can tighten down the strainer without any added reinforcement. Good luck,craig
