Re: Gas Gauge
When you turn the key off does the needle stay pegged?
More then likely you have a bad ground wire on the tank.
I just went through this with mine on the 20SF.
After 19 years the ground wire corroded on the tab welded
to the tank. I had to tap the fuel gauge to get it to return to "E"
Hopefully you have an inspection port above the sender
to check it....
Good Luck, Ken
