Old 09-29-2011, 07:08 PM
Get new o rings for the t stat covers also liberal use of vaseline on the threads and o rings as they can leak and corrode the sparky plugy thingies.
Salt comes out of suspension at 160 deg so you may have some cooling passage blockage. Check that. The motah will run rich w/o stats so decarb the motah as well. My `96 150 runs at 147.
Harbor Freight has infra red temp guns for really short money. Shoot each cylinder on the muffs. Don`t turn the hose on more than half flow or so. Over 45psi or so is a no no.
Change out all lines from the tank to the motah. New Racor and bulb too. Avoid E 10 like the plague.
Use only Champion QL series plugs. I don`t like it either. Your electronics will thank you though.
Some folks seem to like the Pennzoil semi synth. 15 clams @ wally. I also pre mix, but that`s up to you.
Cheers,
GFS
