Originally Posted by scowman
That's good time for that work and your result looks clean and professional. May I ask what tools you used to clean the inner transom skin? Looks like power tool marks. Maybe an angle grinder? What blade?
Can you also tell me how you got the wood out from around the edges? That can be real PITA.
Cheers,
Ken
Hi Ken,
First I measured the width of transom at Top, Middle, and Chine to chine also from Port gunnel to Starbord Chine and visa versa. I recorded all these measurements First and would re -measure so to keep track of the movement of the hull.
Then i used a block as a jig and traced the outline inside the hull..
Then i used a 4" angle grinder with a diamond blade. and cut on the lines
When I got to the top cap. I pulled all the screws out about a third up the lenght of the cap and used my Hoist to lift it up.. I then cut the rest of the transom up.
I put a few blocks to hold the cap up and just started to pry and pull the rot off the back...
I used a Bostich 36" wrecking bar, a eastwing claw hammer , a craftsman ballpin, and 2 steel flat wedges and some old large flat head screw drivers..
The rot was significant so it really wasn't so bad... as for the corners.. I tried to get the most out in the middle of the transom and then with the hoist and some notches in the wood. I used the hoist with a rope tied to the notch to Pull up and it rolled out the plywood for the most part in one piece...
when all the wood is out. I used a mirror to inspect the back side of the glass around the perimeter .. and a very sharp hand chisel i used to chisel out the remaining wood from the glass...
I then used a 7" angle grinder with 36 grit and ground the inner glass down. In some places I had to use a 4" flap disc and or twisted wire cup wheel for the stubborn areas.. I washed the area with acetone and then I scrubbed and Pressure wash with degreaser..
