Thank you all.
Plan is as follows. Everything will be cut and dug from bow to stern. Stringers will be foamed and glassed, they will also be extended and joined to the transom, similar to Shine's work (awesome work by the way). When that is done I plan to move to the fuel tank which will be sitting on a fiberglassed piece of plywood maybe ½ or 3/8 not sure what the glass guy said at the moment. I would also like to put a couple of stardboard pieces there to avoid any corrosion in the future. Tank will be sanded and gelcoated 2 layers.
How does that sound up to now guys?
After that is done I will run my hoses for all my electrical stuff to run through and sealed the sides to further prevent exposing water to the new foam and foam at the level of the stringers or basically below the floor level.
