Old 06-17-2013, 08:59 PM
There's one other thing to look out for. A thick inner laminate spreads the crushing/puncture loads from the engine mounting bolts. Your thin laminate won't, so either get large fender washers or plates to spread the load over a larger area.
Dave
You could also install some brass or SS sleeves in the holes for the engine mount bolts to help carry the crush loads.
Don's right about the I-beam concept for cored construction. Equal laminate thickness on each side of the core would create maximum stiffness, but I suspect most boat builders are inclined to cut corners and reduce cost on thickness of the inside laminate!
