  #124
Old 05-19-2014, 11:07 PM
Strick its all the nuclear waste that make them big! fishing has been good and getting better.
I had a few hours and an extra set of hands this afternoon to help me get the deck out of the boat.
I have some work to do under the decks before the they go in permanently.
I installed the neoprene strips on the the beds for the tank, and started installing some sleeves for rigging. I cut the holes 1/4" bigger and fill around them with dynaglass thru a caulk tube. I cut the pvc a little bigger and then grind them flush with the hole.
the gas tank grew by a half inch somewhere along the way and it is infront of the rigging tubes by a 1/2" its alright I am just gonna cut pvc to fit through the bulkhead and then deal with rigging
I couldn't deal with the stupid 2x4 going down through the center of the floor box so out it came, I cut a piece of 1" foam that I bonded in there and I am going layup a couple layers of mat and roving to smooth it out for gelcoat. the foam is 1.5" w and 2" tall to create a hard right angle for strength. the front floor box and the bilge will be white gelcoat.
and strick this one is for you. 51 pounds
36' Yellowfin
1972 20' seacraft 140 suzuki
