Additional Infomation
1975 SEACRAFT SCEPTRE
One of twenty six inboard models made. Original gelcoat, no paintwork. Bow rails, aluminum frame windshield with tinted glass, teak swim platform, two sets SS bimini bows and canvas for template. Wilcox Crittenden head in cabin, VHF radio, Ritchie F-82 compass and Garmin GPS. Marine Power 350, Rochester four-barrel, 260HP, (new 2014 GM longblock), raw water cooled, Borg-Warner 71C V-Drive, 1 Ό SS shaft, 16 x 15 bronze prop. with cup. 20 knots cruise @ 2800 rpm, 30 knots @ WOT.
2003 Float-On Aluminum I Beam torsion axle tandem trailer.
2003 Improvements:
2003 Float-On 6000# Aluminum I-beam trailer with disc brakes
New 65 gallon fuel tank and all lines replaced
Decks rebuilt
Carberator rebuilt
All cooling hoses and claps replaced
New alternator, battery and cables
New SeaCraft emblems to match originals
New Morse single lever control
2004 Improvements:
New Faria gauges and digital depth with shoot thru hull transducer
New woodgrain dash panels engraved to match originals
All running gear removed, machined replaced/repacked, shaft straightened, new cutlass bearing
New antivibe engine mounts
New exhaust manifolds, risers, mufflers, hoses and clamps
New Jabsco bronze raw water pump
Rewired at engine, dashboard and switch-panel
Cabin doors repaired and varnished
New cabin cushions
New Blower
New transmission overtemp indicator light and bilge pump running indicator light.
New 360 gpm manual bilge pump (automatic pump is 1500 gpm with warning light on dash)
2005 Improvements:
Seats and engine cover re-upholstered.
Exhaust through transom fittings replaced
Transmission painted, cooler and lines replaced and shift fluid valve seal replaced
Starter motor replaced
Rodholders and aft bulkhead battery compartment door refinished
Head and associated seacocks, hoses and clamps replaced
2006 Improvements:
Replaced steering cable
2007 Improvements:
Rebuilt raw water pump
2009 Improvements:
New Mallory YLE Distributor
2010 Improvements:
2012 Improvements:
New manifold Risers
New Rebuilt Carburetor
2013 Improvements:
New manifolds
Rebuilt cylinder heads
All new trailer bearings and seals
2014 Improvements:
Bilge painted white
New GM marine longblock (399 hours on meter)
New oil engine cooler and lines
New alternator
New raw water hoses
New exhaust silencers
