Old 06-02-2015, 10:28 AM
MarkR MarkR is offline
Default Additional Infomation
1975 SEACRAFT SCEPTRE
One of twenty six inboard models made. Original gelcoat, no paintwork. Bow rails, aluminum frame windshield with tinted glass, teak swim platform, two sets SS bimini bows and canvas for template. Wilcox Crittenden head in cabin, VHF radio, Ritchie F-82 compass and Garmin GPS. Marine Power 350, Rochester four-barrel, 260HP, (new 2014 GM longblock), raw water cooled, Borg-Warner 71C V-Drive, 1 Ό” SS shaft, 16” x 15” bronze prop. with cup. 20 knots cruise @ 2800 rpm, 30 knots @ WOT.
2003 Float-On Aluminum I Beam torsion axle tandem trailer.
2003 Improvements:
• 2003 Float-On 6000# Aluminum I-beam trailer with disc brakes
• New 65 gallon fuel tank and all lines replaced
• Decks rebuilt
• Carberator rebuilt
• All cooling hoses and claps replaced
• New alternator, battery and cables
• New “SeaCraft” emblems to match originals
• New Morse single lever control
2004 Improvements:
• New Faria gauges and digital depth with shoot thru hull transducer
• New woodgrain dash panels engraved to match originals
• All running gear removed, machined replaced/repacked, shaft straightened, new cutlass bearing
• New antivibe engine mounts
• New exhaust manifolds, risers, mufflers, hoses and clamps
• New Jabsco bronze raw water pump
• Rewired at engine, dashboard and switch-panel
• Cabin doors repaired and varnished
• New cabin cushions
• New Blower
• New transmission overtemp indicator light and bilge pump running indicator light.
• New 360 gpm manual bilge pump (automatic pump is 1500 gpm with warning light on dash)
2005 Improvements:
• Seats and engine cover re-upholstered.
• Exhaust through transom fittings replaced
• Transmission painted, cooler and lines replaced and shift fluid valve seal replaced
• Starter motor replaced
• Rodholders and aft bulkhead battery compartment door refinished
• Head and associated seacocks, hoses and clamps replaced
2006 Improvements:
• Replaced steering cable
2007 Improvements:
• Rebuilt raw water pump
2009 Improvements:
• New Mallory YLE Distributor
2010 Improvements:
2012 Improvements:
• New manifold Risers
• New Rebuilt Carburetor
2013 Improvements:
• New manifolds
• Rebuilt cylinder heads
• All new trailer bearings and seals
2014 Improvements:
• Bilge painted white
• New GM marine longblock (399 hours on meter)
• New oil engine cooler and lines
• New alternator
• New raw water hoses
• New exhaust silencers
