Old 03-29-2016, 01:36 PM
many scalps many scalps is offline
Default shoreline trl.
Denny, you as well as the other members on this site are amazing.The information and knowledge you supply is beyond incredible.I hope you're doing well.
Yes,we did speak about this issue a bit over a year ago. **I have tried everything when it comes to roller placement and weight distribution.**I've tried dunking the trailer and floating the boat on**. I've tried just backing the trailer in partway and even hardly in the water**,I've tried adjusting the spread on the rollers in several different ways**. I've put tall guide ons placed near the stern end,and they work fine in keeping the boat from going off center but don't help in keeping the hull from listing severly to the side(mostly to port)**
I think what I'm dealing with are a few different problems with this trailer. I think that even though its rated as a 6,500 pound capacity it is a little to ismall. I also think it doesn't have enough rollers.
The arms on the rollers are not very long so I can't get the spread I need.Also the bend on arms that hold the rollers aren't high enough to clear the lips of the steps(panels).so even if I could get the rollers close enough to the lip the arms would dig into the hull.
I gave some thought as to trying larger diameter rollers but with the price. The trailer is a SHORELINE and oem parts are not available.
I thought about buying a new trailer,but I have literally only a 1/4 mile to the launch ramp, so laying out a few thousand dollars for a new trailer seems un realistic.Hopefully the bunks will help.
Thank you all for your help.
I had the same problem with a shoreline trl. years ago. could not correct it sold it and bought a EZ load worked fine Good Luck , Fritz
