Originally Posted by UrbanAngler
should I start with biggest pieces first, as recommended by West System, or start with smaller pieces and build up to the largest, as I have read elsewhere?
The largest first and then smaller is more for corners and laying up over filets. In your case I would start with the small and work out to larger.
What should the exact height of the new transom be?
A lot of boats are around the 24-25" range but on a seacraft I like to go back to 26-26.5" on the height so that the motor is not jacked up so high off the transom to get the av plate out of the water. It will keep more water out as well.
