Thread: Suzuki ?
Old 04-14-2019, 09:32 PM
FLexpat FLexpat is offline
Seacraft hulls need the AV plate high to get clear of the water. BEFORE you go playing around with props, just look over the transom while you are at cruise - if the AV plate is not clear then raise it. Repeat until it is clear. The 23 likes 2-3inches. I have talked with guys running them as much as 3.5 up without a bracket. The 'right' prop with the drive buried is probably not the right prop with the drive in the right place. A buried drive will cost you fuel and speed.
