Old 11-12-2019, 01:21 PM
Originally Posted by Locke N Load View Post
So, 1708 is easier to work with than 17oz cloth since it is stitched with CSM on the back to keep it's shape? The tradeoff being you have to use more resin to wet it out and don't get much if any extra strength from the CSM? My plan has always been to wet out an area, lay unwetted glass on and then wet out the glass. Squeegee and roller to get air out and excess resin off.
Pretty much... 1700 becomes like a snakeskin when wet. 1708 much more manageable.
Every situation is different and if i can wet something out outside of the boat then transfer i will. Otherwise yes wet out underneath, put dry glass on, fully saturate it and hardroll it. You dont want dry layups, so wet out first and let it absorb into the core a bit.
