I have seen pictures on here of the molded splashwell if that is what you are talking about. Do a search for that or just a google search for 18 Seacraft and I bet you will see that. Mine had a glassed-in version of that when the previous owner ran scuppers through the bottom of the hull. It would fill if you stood in the corners. I tore that out and ran them out through the transom like original. I put a lot of time into restoring the gutters and reworking that detail. I pitched the inside of the motor well to eliminate standing water and will still put ping pong balls or flaps this spring.
