Old 09-20-2021, 10:40 PM
FLexpat FLexpat is offline
Hey Mitch-
I am suspicious of my scuppers although haven’t been above to confirm a leak even after five days in the water. Pls tell us more about the fiberglass ones including source.
Thx
Not intending to hijack thread here so I will keep it short. I used 2"OD/1.5 ID pipe from Max Gain Systems (mgs4u.com/fiberglass-tube-rod.htm) and then wrapped it in 1700 w epoxy to get to 3/8" wall. Cut out old stuff and cut sections of pipe to fit angles (neither were easy tasks - access is hard). You can see the blocks in the corners of Petey's bulkhead picture. Centered tubes on old holes, epoxied tubes in w glass fiber fillets then 1700 or 1808 (can't remember which). Match drilled liner n hull to 1.5". Sounds easier than it was, but I wanted to keep the drains which I think are a good idea but miserably executed.
