Thread: Never Again II
Old 02-02-2022, 03:46 PM
PackRat PackRat is offline
Originally Posted by Xcomunic8d View Post
Have a flush trim bit? Once you have a pattern like 1/4” mdf you can crank them out.
If not pm me.., I have.
Btw teak looks good. Using petit flagship?
I know what you mean but this was just a one-off on recycled scrap teak that was run through a planer to get rid of weathered bit. Pieces were only slightly larger that the part I wanted so had to split down the center and have the glue joint.
Used west system/ 207 hardener, couple coats, and a couple coats of clear awlgrip. Would do more coats if in the weather but emblem will be in cabin. Chairs were done same way but three coats of epoxy and 5-6 coats of clear.
