I know there has been some previous posts on removing or keeping the side vents.
I decided to keep them, but tried to replace the plastic style vents with SS flush style vents. Problem, the Attwood (#1499, 3"x17") SS vents have only a 1/2" flange. The old plastic ones have a larger flange (3/4" or more?) Does anyone know of another SS flush vents that are slightly larger to fit? Thanks Nick |
Back to the top, and get my # of posts up!
Any thoughts on this, before it starts to sink again ... thanks Nick |
Heres what I found so-far
Marpac #7-0092 ss overall 4-5/16 x 12-5/8. Cut out 3-3/8 x 12 ************************************************ Det Mar #327557 (7-2-10 white abs #327569 (7-2-2) Black abs overall 4-3/4 x 13 cut out 3-3/4 x 12-1/4 Depth 1" w 1/2 " flush height. ??? Scream'n Reels !
http://www.frenzie.com/frenzielogoline.GIF www.frenzie.com http://www.frenzie.com/custom.htm "Classic SeaCraft" Lures 1983_seacraft_master_angler.]htm My wife and I had words, But I didn't get to use mine."?" |
Gemlux, Gemlux vent page has (2) but they will not fit, figured I would post part #'s just in case.
# 763: Vent Louvered 4.5 X 8.125 In, 3.5 X 7.25 In Opening, Requires 4 # 6 Fasteners # 765: Vent Louvered 4.5 X 12.875 In, 3.5 X 12 In Opening, Requires 6 # 6 Fasteners Both are stamped stainless steel |
The only thing I know to do is to build up the hole from the inside with fiberglass and then gel coat that will make the opening a little smaller for you to screw in the stainless vents into the smaller opening.
FellowShip [img]images/icons/rolleyes.gif[/img] |
