Old 04-30-2010, 08:11 AM
Ryank Ryank is offline
Default Battery Chargers
Just a question, Hopefully someone knows an answer to. I have an older Bomar battery charger in like new shape. It charges great, and when it's done, goes into a "float mode" where the amp needle bounces around from 0-5 or so. The voltage ouptut is still 13.4 volts. I was concerned this would overcharge batteries so I looked at new chargers. They seem to do the same thing go into a "float mode" with an ouput still of 13.4 volts. Is the voltage continualy feeding into the battery at 13.4 harmful and will it cause overcharging or is it the amperage that is harmful to batteries therefore making my charger ok to still use?
Seacraft's for life !!!
Old 04-30-2010, 09:29 AM
makade makade is offline
Default Re: Battery Chargers
I just installed a Deltran charger. Check out their website, there's a lot of good info.
http://batterytender.com/
Old 05-04-2010, 02:32 PM
joshmon71 joshmon71 is offline
I added a promariner prosport 3 stage charger last summer, and 2 AGM's honkers from Sears(odyssey brand). Nocomplaints. At same time I as well added a BEP battery switch cluster which has a built in VSR, so i can charge both batts isolated while running. No more of that 1 or 2 thing or gasp parallel)and it prioritizes the engine batt first. Very happy.
1977 Seacraft, Armstrong Bracket
275(chipped 250!) Verado
Merc Rev 4 17P
Old 05-06-2010, 02:11 PM
I use a 2 -4 -6 amp charger that just cuts off when fully charged, has an LED gauge. I have had others that do that and didn't think it was an issue but 5 amps is a pretty good charge.
WM $28
Old 05-08-2010, 01:35 AM
seabob4 seabob4 is offline
A ProMariner ProSport 20+ will do the trick...
