Old 12-29-2010, 10:55 AM
DANNY18SC DANNY18SC is offline
Default johnson commercial 155
has anyone ever had any experiences, good or bad, with these motors? the guy said he just had it rebuilt and hasnt even broken it in yet. would this be too much for my 78 18ft? this might be a deal i cant pass up, but dont want a motor with alot of headaches.
78 18'
89 200 Yamaha
http://i1215.photobucket.com/albums/...1227/boat4.jpg
Old 12-29-2010, 11:57 PM
Default Re: johnson commercial 155
What year? With or without the VRO system?
Fr. Frank says:
Currently without a SeaCraft
Old 12-30-2010, 01:25 AM
Low compression motor, they run on the worst of fuel. I forget the octane they can run on. Good smokey old motor, they were the predominant motor on the back of towboats for years. 155 I think was basically a 185, bigger lower, couple other things.
Old 12-30-2010, 03:59 PM
89 motor. the guy said the VRO was disabled, if it isnt and i get it, i will disable it and mix my gas. do you think this wee be too much weight for my 18? i looked it up on NADA, says it weight 400 lbs. being a low comression motor, what #s do i need to look for on a comp gauge?
78 18'
89 200 Yamaha
Old 12-30-2010, 07:13 PM
I just sold a boat with a 1989 150hp Johnson "cross-fire" motor (not a looper). I've had four of these type engines and they never broke, just wore out. I thought the 88hp, 155hp commercial marketed motors were mix your oil only type engines. That way, no worry of VRO failures.
Old 12-30-2010, 07:31 PM
My '90 88 SPL's were mix your own.
Old 12-30-2010, 11:24 PM
seacraftks seacraftks is offline
a 155 cant say i ever recall seeing one
Old 12-31-2010, 11:40 AM
pelican pelican is offline
you're correct...the spl's and commercial engines,had no oil injection...
also,"low compression engines" ? it's a 2 stroke,the compession ,ratio is much less than a 4 stroke engine...that comment concerning "it's a low compression engine",it's incorrect...
Old 12-31-2010, 01:30 PM
They don't run a different cylinder head on those than other crossflows?
Old 01-01-2011, 02:35 PM
CaptMick CaptMick is offline
For what its worth I have a 417 pound 150 Merc on my 18 without any changes to scuppers or deck and I am fine. Hull is an 85.
