Old 05-29-2012, 05:35 PM
realdealz realdealz is offline
Default 85 23' sea craft scupper drain questions
I am looking at a 1985 sea craft that is for sale. The transom has been redone and now it has a 300 HPDI mounted on a bracket. But the scuppers drain into the bilge area. Is this normal for these boats and how could it be changed to drain out the transom as most boats do.
Old 05-30-2012, 04:33 PM
shine shine is offline
Moderator
With a 300 on a bracket the standard sole height is probably right at or below the waterline, at least at the transom it is.
they are drains, not scuppers
That's a very bad set up in my opinion, you should have a way to drain the cockpit even if it means check valves of some sort. Loss of ability to self bail is a huge compromise in the seaworthiness of the boat.
Old 06-01-2012, 04:01 PM
dgixxer252525 dgixxer252525 is offline
I have this issue as well. Right now the deck drains into the bilge and it drives me crazy. I have two bilge pumps that keep things dry down there, but knowing its not set up the way i want it is what stinks... I was thinking of putting some of those flapper type scuppers right next to/under my bracket right above the waterline. i could them run hoses from my deck drains to these flapper scuppers...maybe you could try this?
Old 06-01-2012, 07:12 PM
Seacrafts do not drain into the bilge. Thye are self bailing but a poor design. Either you have a modified seacraft or you own something other then a seacraft.
Old 06-01-2012, 08:09 PM
Sorry I wasnt as clear as I should have been...i have a 1983 modified 23 with a bracket...are the flapper scuppers basically a form of what you called a "check valve?" If so, what do you think of my idea? Better than draining into bilge im thinking...
