Old 09-15-2012, 06:52 AM
GoodChance GoodChance is offline
Default Don - Question for You
Hey Don ...... Are all of your motor brackets designed the same way? In other words, if I wanted a 30" shaft motor instead of a 25", would you build a "special" bracket for the longer motor?
Or are all of your brackets the same regardless of shaft length?
If they are the same, do you see any performace "negatives" with installing a 30" shaft on a standard (universal) bracket that you make?
I can see several "positives" with installing a 30" shaft motor but want to see your point of view on this matter.
The Idiot Who Re-Built the Burnt-Up 35 Duffy
