Old 03-10-2018, 03:00 PM
Jasnyder1 Jasnyder1 is offline
Default 23 Project saved from the vineyard!
Thanks to the help of No Bones and Eric I was able to save this savage from a little vineyard near us. The boat was only registered for eight years, I washed the hull a little bit and it’s crazy the condition of the exterior, very minimal fairing before painting. The decks are solid as a rock so I’m going to try to keep them and the original non skid pattern. I’m going to do the transom and re core the cap then paint of course and add a bracket. Maybe single 300? Does anyone know the name of this color? I’d like to keep it as original as possible. It may take a while but here are some pictures to start!
Old 03-10-2018, 05:25 PM
Nice score! I want to see Gucci complete.....
Keep the boat porn pics coming :
BTW: that color is Potter era "Robins Egg Blue"
Old 03-10-2018, 10:30 PM
Damn Bro, nice freakin’ score! Congratulations!!!
Old 03-12-2018, 10:07 PM
I did some transom prepping yesterday and took some pictures, I plan to use 1 1/2” coosa with epoxy resin. Due to someone cutting it from the outside and the inside glass being thin and junk I decided to layer it all up on the outside, let that cure then cut out that inside layer and do all new inside glass. You’ll see in one of the pictures when I moved the cap to do some grinding it says “Show Boat.” Not sure what that was for maybe meant for a boat show but I thought it was cool.
Old 03-18-2018, 08:39 AM
ScottM ScottM is offline
Dieter Sprockets
Is she a factory Savage? If so you have a pretty rare bird.
Old 03-18-2018, 08:00 PM
Yes sir it is, I didn’t know so few had been made till I found the build numbers on here. And this is my second legitimate savage believe it or not. I guess I luck upon them.
Old 03-20-2018, 07:35 AM
NaturalHigh NaturalHigh is offline
Aaron, looks like the vineyard boat is on its way to a new life.i hate to say it but you might have her done befor I get mine done. I still have the old teak doors u can have they need some work
Old 03-26-2018, 08:49 PM
Default Weekend work
I got the chance to do a lot this weekend, ground out the old core in the cabin floor and put new divinycell in. Time to grind and fair that out. Made all my tank beds and glassed the bottom tips before I tab them into the hull so they’re sealed for water to run under them. I pre fit the box that I cut out of the front to go in the back as floor storage, should be a nice big bin. I cut the floor straight from where the original tank hatch sat, straight forward another 3-4 feet so I can fit a 130 gallon tank in there. I thought I was gonna find rotten spots where the console was mounted but not a single rotten area, I can’t believe it but I’m not complaining.
