Hi, my name is Dave, I'm new to this board. I don't have a classic Seacraft, but do have a newer one that I was hoping I could get some help with. Mine is a '99 23CC with a 225 Optimax. The prop is an Offshore four blade with a 19 pitch. I am only able to get the RPM's to around 5000-5100 and would like to get closer to the max of 5700. Any suggestions from people with a similar setup would be greatly appreciated. Thanks in advance.
Cheers Dave |
Dave, you need a 17 inch pitch Mirage three blade stainless prop. I believe most guys with a 225 opti on a 23 sea craft use this prop. There have been numerouse threads on this subject so you may want to do some research on this website. I have a 225 opti on mine and that is what I use. I am not 100% sure but I believe the diameter is 15 1/2. At any rate, I would consider switching to the mirage. I max out at about 5700 rpms. good luck
Steve 1978 20 ft. Master Angler (175 merc) 2000 23 ft. Seacraft (225 opti) 1984 17ft. Boston Whaler (90 merc) |
Thanks for the reply SteveH. When I enter my numbers into the Mercury prop selector, it gives a number of choices from 15-17 pitch. I wanted to get some input from other Seacraft owners before I make a decision. Thanks again.
Dave |
Make sure it's a Mirage Plus, not just a Mirage, you can pick one up on e-bay pretty cheap...under $200 for sure.
mine is actually a "mirage plus." I have other props of various sizes and have found that this is the best prop for the 225 opti in my opinion.
Has anyone tried the Enertia prop on this setup? I talked to Ken at PropGods and he raved about this new prop, but he has no experience with a Seacraft.
Dave |
The merc offshore prop is not good match for seacrafts . . . Vensura/Offshore are bow lifting props . . . Mirage Plus or Rev 4 are the merc props you want to look for.
Thanks again for the responses. GFS thanks for the offer, I am in Maryland and won't be able to make a trip to FL. Had to figure out what Long Point was, sounds like a good time. Maybe a future gathering.
Dave |
