Old 05-31-2009, 01:13 PM
travisrandall travisrandall is offline
Default hull id locations
I cant find one? the original place on the back of the transom has been either glassed over or removed. is there anywhere else it would be?
Old 05-31-2009, 05:59 PM
Default Re: hull id locations
Depends on the year. My 72 had no HIN on the transom, just the 4 digit serial no. on a decal below the helm, almost illegible, and the same 4 digits engraved into the starboard stringer about 1.5" tall, almost completely hidden by foam. I cut about 1" of foam away to fully expose the numbers.
My previous pre-73 SC hull also had the serial no. engraved in the starboard stringer, about 8" forward of the transom.
Even with that the state of FL assigned a full length HIN when I titled the boat (previous title was CT), but as my original serial no. was available, I did not have to engrave it into the transom.
Fr. Frank says:
Currently without a SeaCraft
Old 06-01-2009, 06:02 PM
Guest
Posts: n/a
Frank,
Did Florida use a "SIC" MFG code or a "FLZ" MFG code when they assigned that HIN to your 73?
Old 06-01-2009, 07:35 PM
FLZ
Fr. Frank says:
Old 06-01-2009, 10:18 PM
Guest
Posts: n/a
Thanks. FLZ translates to a "Home made" boat hull. Wish they had used the SIC code.
Old 05-31-2009, 09:51 PM
The metallic decal on my Seafari is on port side below the teak board/shelf, just aft of the cabin bulkhead.
