Anyone have a clue as to where to get a flywheel puller / lift ring to lift engines with a hoist? I never expected the hoist to be the easy part buy I have one of those.... Where to get a flywheel puller with a lift ring - and are they universal between engine manufacturers....
Thanks, John
Surf and Boat fishing for Striped Bass http://striped-bass.com/images/sb_small180b.gif |
Bought both for my Mercury from Merc dealer. Expensive about $35 for ring and $70 for puller but they are really needed. I don't know if they are universal but looking at mine I would guess not. Take a look at the top of your flywheel where both attach and I'll bring mine to the MSBA meeting for you to look at. If I get my engine back on and running before you need them, you can borrow them.
John try NAPA or Auto Zone or Sears for the flywheel puller, I used one we had at work which was just a universal puller and worked great, good luck [img]images/icons/grin.gif[/img]
I support the I'm glad I can afford one boat theory! |
Thanks guys... I know I can get the flywheel puller at auto stores but the big thing stumping me is the lift ring
Anyone else have a thought to where to buy the lift ring?
John, why you needin a lift ring? Is it for the Rude or the new Yammi?
On my Rude, a standard harmonic balancer puller works fine to pull the flywheel.To lift the engine off the boat, I use those 3 same holes you do for the puller, put washers on the bolts and run a piece of chain from bolt to bolt to bolt with 3-4 extra links in between each one.Grab your 3 chain loops and stick them in the hook of the hoist. This is what I've always done, never a problem. Just a thought. Bill |
What outboard are you lifting?
