Old 08-14-2003, 08:39 PM
Ed Ed is offline
Default Sending unit installation??
Hi gents-
my sending unit crapped out. I first checked to see if it was the fuel gauge by disconnecting both wires at the tank, crossing them, and then turning on ignition. My gauge and one of John R's spare gauges...both went past the full mark...which as I understand means that the gauge(s) are good and the sending unit is bad.
My question to you...is there anything special I need to know about installing a new sending unit. To me, it looks like I disconnect the two wires, unscrew 5 hex bolts, remove unit & gasket, and replace with new unit & gasket, and reconnect wires. Anything else? Also...any idea as to how much a sending unit costs??
As always, thanks in advance.
JOHN R- Do you want me to send you that fuel gauge back? If so, let me know your address so I can drop it in the mail. Thanks!
Old 08-14-2003, 09:21 PM
RS RS is offline
Default Re: Sending unit installation??
Ed,
Try this link to the Hull Truth thread
http://thehulltruth.com/6/ubb.x?a=tp...1&m=5516045793
Best regards,
Roger
1979, 20' Master Angler
Old 08-15-2003, 09:35 AM
ScottM ScottM is offline
Dieter Sprockets
Ed,
Figures this happens one day before you head to Nantucket. Hopefully you get it taken care of today. Although with the way that engine idles so low, you could just spit gas at the carbs and she'll run! [img]images/icons/tongue.gif[/img]
BTW, I got my package yesterday, thanks buddy! [img]images/icons/smile.gif[/img]
Old 08-15-2003, 12:43 PM
It will help if you line up the correct bolt pattern and make a mark on both the new and the tank as they have to be lined up the same way they came off. Another way to test it after it is out or your new one is to put a Volt Ohm meter on it and check for resitanse as there will be none with the float all the way up and more as the float goes down towards the empty postion. Also use a nice torqe pattern (opposites and light until they are all snug)when installing the new unit. craig
Old 08-15-2003, 04:37 PM
John R John R is offline
<font size="2" face="Verdana, Helvetica, sans-serif">Don't drop a flaming rag into the opened tank, other than that I have nothing to add....
Come to the next MSBA meeting and bring the guage and my Tubes [img]images/icons/grin.gif[/img] - no need to ship it.,..
Thanks,
John
Surf and Boat fishing for
Striped Bass
Old 08-15-2003, 06:12 PM
SEAFARI SEAFARI is offline
Ed, Tempo makes 2 sizes depending how high your
tank is, about 25-30 bucks. i think the bolt
pattern is pretty standard.
chris
