Old 01-14-2005, 10:13 AM
abl1111 abl1111 is offline
Default rod holder angle ?
What is the rod holder angle, 15 or 30 degrees, for the original, stock marinium rod holders ?
I sat w/ a protractor the other day and could not figure out where to measure?!
Thx
Old 01-14-2005, 10:20 AM
gbf03 gbf03 is offline
Default Re: rod holder angle ?
I would think you would want a 30 degree angle but i could be wrong. All he ones on my sc are 30 but there not original.
-George
20 SEACRAFT SF / 29 SEA VEE
F.S.U. / REEL SWEET FISHING TEAMS
Old 01-14-2005, 10:59 AM
JW-Tex JW-Tex is offline
The oringal ones in my 1969 are all 30 degree. I just bought some new 30 and 15 degree holders.
Moesly 1969 20 CC & Potter 1978 23 CC (23 in storage awaiting rebuild)
Old 01-14-2005, 12:01 PM
RS RS is offline
I usually see gunwale rod holders at 30 degrees and transom mounted and leaning post holders at 15 degrees
Best regards,
Roger
http://members.cox.net/rhstg44/Misc/...go%20small.jpg
1979, 20' Master Angler
Old 01-14-2005, 12:22 PM
Scott Scott is offline
I agree with Roger
My originals are 30 degree as well as the new ones …
30 degrees in the gunwales, 15 in rocket launcher or “maybe” limited space mounting and 90 for storage.
I personally wouldn't trolling out of something less than 30 degrees.. especially bigger fish..The more vertical the holder, the more strain and pressure on your tackle…even 15 seems a little steep for a working rod holder.
I have to believe your holders are 30's but if you want to be sure Just flip the holder upside down , place the flat edge of the protractor on the mounting flange, align the middle (the index mark for using the protractor) of the flat edge with the front or back of the holder(tube) and see where it intersects on the arch of the protractor.
Old 01-14-2005, 12:58 PM
gw204 gw204 is offline
The original Marinium rod holders in my Grady are 30s.
Brian
1981 Mako 17
Old 01-14-2005, 03:48 PM
ScottM ScottM is offline
Dieter Sprockets
Scott,
Is that diagram for figuring out how to cut the holes to mount the holders? I need to mount a couple more in the Seabird but I don't exactly know the best way to cut the holes.
Old 01-14-2005, 05:22 PM
That’s just the dimensions diagram from Lee
http://www.leetackle.com/04dlee.html
Old 01-14-2005, 07:40 PM
Scott- take a piece of cardboard and make a template of the base part of the rod holder/angle and then mark your holes. pretty easy to make and works well. since the template wont be as thick as the actual glass though I use a big rasp to remove the extra material after i cut the hole( then sealed the holes before installing the holder.
Old 01-15-2005, 09:12 AM
RS RS is offline
I used a hole saw held at a 30 degree angle, more or less. Then I used a dremel with the mini drum sander for the final fit. It was pretty easy.
Best regards,
Roger
