Old 06-11-2006, 11:16 PM
gatorbait gatorbait is offline
Default Ablative Paint Removal
Anyone had any success with removing ablative paint? I've tried stripper and it's a mess with the chalky nature of ablative paint. Sanding is a mess too, when the dust settles on you, your dog, and your trailer and becomes somewhat permanent. I was thinking of renting a 3500-PSI pressure washer and trying to blast it off???
My plans are to remove the bottom paint down to the gel coat, sand, and reapply a new layer of gel coat. Any advice is always appreciated, thanks.
I need some help!!!
Old 06-12-2006, 10:46 AM
Bryan A. Bryan A. is offline
Default Re: Ablative Paint Removal
I pressure wash mine every year to clean it, not remove it and it seems like plenty comes off. I also wet sand the waterline area to remove the stuff that doesn't sit in the water but discolors. That removes alot also and the best thing----- no dust. I use Shark White Micron Extra as the paint. I would try pressure washing.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 06-12-2006, 08:23 PM
Thanks Bryan,
I think I'll rent the pressure washer for $50, give it a whirl, and clean my roof while I'm at it. If that doesn't work, I'll look into the Soda Washing. I'll post my results after this weekend. Thanks for the help!
Old 06-13-2006, 09:48 AM
warthog5 warthog5 is offline
I assume you have composite shingles? [fiberglass shingles]
Be VERY carefull doing that. You can cause a lot of extra wear and tear on the roof.
A better methiod that I have used is to buy swimming pool Clorine [sp?]
Put it in a pump up sprayer and coat one half of your roof. Then just hose it off with the garden hose. Then do the other half the same way.
No scrubbing needed or wanted. No high preasure to screw thing up.
Old 06-12-2006, 11:26 AM
mbo_1971 mbo_1971 is offline
I plan on having mine soda blasted. sounds like the best solution I have been able to find. Curious if anyone else has done it and how they found the results.
matt
