Old 03-26-2008, 07:54 AM
waltert waltert is offline
Default 225 HP Evinrude on 18 CC
Hi All,
I have a 1989 18 CC with a 25" transom, this model was offered with a 150 hp V6 from the factory, I have a good 225 V6 Evinrude that i am thinking of hanging on the boat, I know it will be tons of power,,,, does anyone know how much heavier the 225 V6 is than the 150 hp V6. Will the extra weight be to much?
Thanks,
Walter
Old 03-26-2008, 09:05 AM
peterb peterb is offline
Default Re: 225 HP Evinrude on 18 CC
Walter,
According to the NADA web site, a 225 seems to be about 75 pounds heavier.
Also, the boat was rated for up to 150 HP. That seems to be a lot of power and weight.
It will be interesting to read some of the other responses.
Peter
Old 03-26-2008, 10:14 AM
76Red18 76Red18 is offline
The 150 Johnson on my 18 weighs around 375. Maybe with a new transom and a 3" raised deck I would consider more weight. IMO the hull would handle 225hp with no problem. Insurance companies and the Coast Guard wouldn't have the same opinion though. Hermco installed a bracket on an 18 powered by a 175. I'd love to see some performance numbers on that and hear whether the owner thinks it could handle more weight and hp.
J. M. Hendrix
Old 03-28-2008, 12:38 AM
vcs vcs is offline
I have the 18 with the Hermco Bracket and Evinrude 175. The Full flotation bracket makes a difference. With the prop I have on it, it will run 50. The boat handles well it gets up on plane fast and has plenty of power. My brother-in-law calls it a Ferrari. I would think twice about putting that large of a motor on your boat. Before I had the work done on the boat it had a 20" transome and with a 150 evinrude, it sat low in the water and always had water coming in the scuppers. I think even with your 25" transome you will have water comming in the back. Just a thought
Old 03-28-2008, 06:24 AM
As vcsjupiter was saying, well maybe in another way. As long as you are going forward you will do just fin. Just don’t put it into neutral and forget reverse.
Now lets ask another question could you mount that big of a engine on that small of a boat. Yes the bass boaters do it all the time but the boat was designed to handle it AND to handle it in FLAT water. The money you would save on the engine would be spent on the boat to re design it beyond the manufacturers intention. So the real question is do you want to re design your Boat???
FellowShip
Just for the Grins
Old 03-26-2008, 10:23 AM
I would think a 25" transom would also be a must.
J. M. Hendrix
Old 03-26-2008, 10:33 AM
You could do it and just work around the weight and speed differences. There has been an 18SF in the Tampa area that had a 225 on it for a while. The only reason to do it is the cost savings tied to having a motor on hand to hang on the boat(which is how many of us make decisions to boat these days [img]/forum/images/graemlins/tongue.gif[/img]).
Old 03-26-2008, 01:34 PM
Keyscruz Keyscruz is offline
I have a 1978 18 cc with new raised transom and alum bracket with large flotation chamber. New etec 150 which weighs 430 lbs. Cockpit drains fine but probably would not without the bracket. Don't know speed #s yet but it begins to get squirrely at wot. Boat US will probably insure at an agreed value.
Old 03-26-2008, 02:20 PM
Briguy Briguy is offline
Once when I was in the keys I saw a 20 on a trailer with twin 2.5 merc's on it. No kidding.
Capt. Brian
Old 03-26-2008, 06:29 PM
SUICIDE !!
See ya, Ken
