I need a 8' long battery cable, can I bolt two 4' sections and heat shrink the connection?
Go to your local welding supply shop and buy 1/0
or 2/0 cable from them. Solder on the copper ends and use red heat shrink to identify the positive cable. Splicing could cause a current lose. See ya, Ken
See ya, Ken © |
Ken is right. You can even buy 2/0 at most Home Depot stores. It ain't cheap, however, at $9 to $10 per foot for single-conductor tinned aluminum cable. But it's definitely the way to go. AWG 2/0 two conductor cable from Pittsburg Wire is really good quality stuff.
Et23, Quit screwing around splicing battery cables. You and your Seacraft deserve better. Do yourself a favor and checkout
http://shop.genuinedealz.com/Marine%...ttery%20Cable/ You order what you'll need send them a separate e-mail with instructions anda couple of days later you'll have the best cables you've ever seen, and money left over for beer, err, gas. They are excellent. Top quality boat cable - tinned copper. Their prices are better than port supply wholesale and they'll cut, crimp your lugs, and heat shrink as few or many connections as you want for $.99 each end. They are fast and accurate. They're based in Brunswick GA. They got my stuff to San Diego CA in 3 day UPS ground. Honestly, I think it's one of the best groups I've ever dealt with. Check it out - I think you'll be pleased. ![]()
I ordered from them also, quality work, decent prices and they custom cut cables to order with whatever lugs you want.
Thanks for the options, I will check them out.
Wow, good stuff down there... great prices, too. Wish I had a shop like that nearby.
et23,
Unless your running a diesel or a thruster, 1/0 should do you. How does $85 sound for 8' of red and black? Pacer Marine, REAL marine cable. Darn close to Ancor cable. Let me know. Need lugs? |
skycraft in Orlando has welding cable and I believe it is cheaper then most places
