Old 04-23-2010, 07:57 PM
Default New to me toys again. Stern vents.
Thanks Richard!
I get to cut more holes in the boat. Now I have to move the bilge thru hulls.
Is slightly lower better? For the thru hulls that is.
One of my silent mistakes will now be covered. That`s why I have the starboard stern box on port. Fits, but not
properly.
Cheers,
GFS
Old 04-23-2010, 11:56 PM
RWatts23 RWatts23 is offline
Default Re: New to me toys again. Stern vents.
Do go cutting just yet! I'll send them out Monday. I placed my bilge thru hull midway between the rubrail and the water line, I thought about lowering it, but I did'nt want to have to worry about water comming in while fishing, or running and pitching in rough seas. I did mount the thru hull for the live well low so that it would drain well- the thru hull for the live well is lower than the live well drain.
Old 04-26-2010, 01:07 AM
Question, why are putting vents on an outboard, just curious
Old 04-26-2010, 09:06 AM
Dr Gucci said the 23s benefit from the vents and my deck will be happier.
GFS
Old 04-26-2010, 09:15 AM
His diabolical plan will be mostly done then! Conversion to a Potter build 20SF. Sandy, the next step is to speed up the transom rot situation .
Seriously-Those vents with the correct ducting does help get air below deck.
Old 04-26-2010, 08:05 PM
Almost ready to PM Dr. Gucci for a couple of stickers.
CSC
Potter Built
by slackers `89.
It will be upside down in protest of slackers inability to use a jig for cutting my dash and console. I could go on, but I don`t want to let her see this. She reads all my posts.
I just moved the ducer and the holes were dry, dry, dry.
Resealed the transom cap w/ 5200 too. Maybe the #1 source of intrusion. Seal everything you can. Every screw you do is one more place you save. I don`t have a Pooh- Bah cave, and rain is my enemy.
What is the proper ducting?
Since I only have two.....one fore and one aft? Or just like the book says
Cheers,
GFS
Old 04-26-2010, 08:36 PM
mr gofast
u needs to put dem vents under the liftin strak under the tow eye..dat mean u gots to keep dat sucka ups on plain or U down to shake da hand of king neptune
he he
sam
