Old 04-17-2011, 10:57 PM
Default 1988 Yamaha 175, stainless prop, tilt/trim
Located north of Boston. AFAIK, it all works. But I have only seen it run in gear with muffs and the tilt/trim. 20" shaft. Kinda ugly, other than the prop.
$1200/BRO, you pick up, or I will part it for a lower unit and T&T
Old 04-18-2011, 09:28 AM
Default Re: 1988 Yamaha 175, stainless prop, tilt/trim
send me some contact info
PM me
Old 04-23-2011, 09:12 AM
OK, it is going on Craigslist. But don't be afraid to ask me to part it out.
Old 04-23-2011, 07:34 PM
red20 red20 is offline
I have the same motor on my 20 MA. Ugly as can be but never lets me down and runs STRONG. No hour meter but I must be around 1200+.
All my buddies laugh at me and say " get a new 4 stroke, that old thing is noisy and smokes a too much."
I respond "gas and oil is way less expensive than a new 4 stroke!"
Old 04-27-2011, 08:41 AM
FWIW, I found about 15 years worth of maintenance receipts for it. Including a new shift shaft, head gaskets, carb rebuilds, coils, etc.
Old 04-27-2011, 11:45 AM
apneadreams apneadreams is offline
4 strokes are so much cheaper short term and in the long run...with a 4stroke you double your gas milage and you are not buying expensive 2 stroke motor oil to burn...4 strokes get longer motor life and are much more reliable...disclosure...I have used both 2 strokes and 4 strokes and will never go back to 2 stroke motors. JMHO
Old 04-27-2011, 01:23 PM
..with a 4stroke you double your gas milage...
I seriously doubt that. 2x the milage? That WOULD be nice.
Old 05-08-2011, 08:10 PM
bzeiher bzeiher is offline
Check your mail... just PMd you.
thanks
Old 05-14-2011, 08:44 PM
In case 76seacraft passes on it...
Ran it today. Compression is less than stellar 80-110 PSI, depending on the cylinder. I have video of it running and the compression tests. I can offer it with a stainless prop and controls, and spare starter. Tilt trim works. Can ship from my loading dock.
A gem? No. But probably good for a season, then a rebuild in the off season. Once again a '88 20" shaft motor.
Make me an offer? I am pulling it next weekend.
Old 06-02-2011, 01:13 AM
$999/ OBO. Or I can part it for TnT/Prop/Lower unit.
