Enough power??? I am thinking of fuel consumption...Would engine have to work too hard to keep boat on plane?????
I would be purchasing a used Johnson 200 hp 1990's Thanks -Fred
"...Southern by the grace of God" |
I had a 1982 Sceptre with a carbed 200 Yamaha. It wasn't a speed demon however it didn't run bad at all. My cruise was 30 MPH and got 2.2-2.3 MPG and it would top out at 39-40 MPH.
Steve B 1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH! 1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop |
![]() Quote:
1977 SeaCraft 23' Sceptre W/ Alum Tower & Yamaha 225 www.LouveredProductsUnlimited.com |
Jim - Was the Excel good on fuel? or on par with the OMC?
Best I can remember the Yami was a little more efficent. I still run the yami now. I ordered a fuel flow sensor (last night) to connect into my Lowrance HDS-7, so soon I will know exactly my fuel mileage etc. I'll post it up then.
The bottomline cruise numbers for a Sceptre 23 w/ a 225hp outboard should be 27-30 mph at about 10-12GPH = 2.2 - 2.5 MPG . If you want to go faster you are going to have to pay exponentially $$ for that additional speed. Fr. Frank is right, and he must have been running a pretty loaded (lots of gear) down boat and full of fuel.
![]() Quote:
If you don't like it swap out the carbs for a 225.
__________________________________________________ ________________ 1974 23SF |
Fred, I ran an '88 Johnson 225 on my '74 Tsunami. I burned about 11-12 gph on the Navman at 24 mph cruise (about 2.0 to 2.2 mpg), WOT was about 37 mph with the motor burning 38.4 gph on the Navman (less than 1 mpg). Pushing cruise speed to 30 mph upped fuel flow to 18 gph, or about 1.7 mpg.
