Old 06-13-2011, 10:29 PM
newboater newboater is offline
Default Fuel tank
any ideas on replacement fuel tank for a 20' Seafari, the one in there now is stainless and appeares to be a flat bottom 47"L X 22"W X 7 3/4 H are the plastic tanks good ??
Frank 1972 20' Seafari
Old 06-14-2011, 12:39 AM
fredetzel fredetzel is offline
Default Re: Fuel tank
Hi welcome to csc Plastic tanks are fine if you can find some that will fit.
You can also have your old one repaired [welded] if its not too far gone.
good luck
1978 sceptre inboard fwc marine power
Old 06-14-2011, 01:52 AM
The tank on my 72 Seafari is tapered on bottom of fore end and top of aft end to allow the tank to be removed without cutting the floor. Pretty good design me thinks... If yours is that way - and salvageable, I'd consider restoration or duplication. Good luck.
Old 06-14-2011, 07:08 AM
Was that the original tank ?? mine was replaced with what looks like painted stainless with steel fittings welded on poor looking welds, getting pin holes around them, that tapered design sounds good any idea where you got it ??
Old 06-14-2011, 09:41 AM
My tank is original and I have the original dimensions written down somewhere. Will dig them out and send later today. Actual volume worked out to be about 34 gallons.
Old 06-14-2011, 05:59 PM
Our 66 bowrider came with a 29 gal stainless tank. Removed and replaced with a 29 gal poly tank. Went from a 110 pound tank to about 20. Definitely a good move & happy with the poly tank 4 years later.
Old 06-14-2011, 09:37 PM
that's a big weight savings, was leaning towards a poly, my Jeep has one since 93 with no problems, no corrosion to deal with, thanks for the help
